Feature |
Product |
Release introduced |
Advanced Feature Bandwidth Reservation Note:
If your switch does not have this boot flag, it is because the hardware reserves the bandwidth automatically with no user interaction. |
5320 Series |
Fabric Engine 8.6 Not supported on 5320-16P-4XE or 5320-16P-4XE-DC |
5420 Series |
VOSS 8.4 |
5520 Series |
VOSS 8.2.5 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
Fabric Engine 8.10 |
7720 Series |
VSP 4900 Series |
Not Supported |
VSP 7400 Series |
VOSS 8.0 |
The switch enables this boot configuration flag by default to use advanced features on the switch. If you disable this flag and attempt to enable an advanced feature the switch displays an error message to explain why the advanced feature failed to start, and to remind you that you must enable this boot configuration flag for that advanced feature.
Important
If you change the configuration, you must save the configuration, and then reboot the switch for the change to take effect.
If you disable this feature and save the configuration, any configuration for advanced features remains saved in the configuration file but is not used.
When you disable this feature, you can use all ports for Layer 2 or Layer 3 forwarding of standard unicast and multicast features. Use this mode if you are not configuring advanced features.
When you enable this feature, also known as Full Feature mode, the switch supports advanced features by reassigning some of the front panel ports to be loopback ports.
The following tables identifies the features that use Advanced Feature Bandwidth Reservation.
Full Feature mode does not support PIM.
Feature support can vary by hardware. For high-level feature support information, see Fabric Engine and VOSS Feature Matrix.
Important
Advanced Bandwidth Feature Reservation must be enabled when using SPBM even if features requiring loopback bandwidth are not used.
| Feature | 5320 Series | 5420 Series | 5520 Series | 5720 Series | 7520 Series | 7720 Series |
| Application Telemetry | Yes | Yes | Yes | Yes | Yes | Yes |
| Bridged and Routed Layer 2 VSNs (C-VLAN UNIs) | Yes | Yes | ||||
| E-TREE UNI | Yes | Yes | ||||
| Fabric Extend | Yes | Yes | Yes | Yes | Yes | Yes |
| I-SID Mirroring | Yes | Yes | Yes | Yes | Yes | Yes |
| Inter-I-SID Routing | Yes | Yes | ||||
| IPFIX | Yes | Yes | Yes | Yes | Yes | Yes |
| IP Shortcut Routing | Yes | Yes | ||||
| IS-IS Accept Policies (Inter-VRF Routing) | Yes | Yes | Yes | Yes | Yes | Yes |
| Layer 3 VSNs | Yes | Yes | ||||
| Multicast over SPB - UNI to NNI | Yes | Yes | Yes | Yes | Yes | Yes |
| Segmented Management CLIP | Yes | Yes | Yes | Yes | Yes | Yes |
| Simplified Virtual IST | Yes | Yes | Yes | Yes | Yes | |
| VXLAN Gateway | Yes | Yes |
Depending on the hardware, this feature supports three modes:
When you select low or high, the corresponding bandwidth of the reserved Ethernet ports is allocated to the loopback required for advanced feature functionality. When you select vim, the bandwidth is allocated from the unused vim slot capacity; you cannot select this parameter if the VIM card is present.
The following table shows the supported modes and the ports reserved as loopback ports by each mode. An empty cell indicates the mode (parameter) is not supported.
For 7520 Series and 7720 Series, you can consider using low bandwidth mode instead of high bandwidth mode to free up two reserved ports for use as regular ports.
| Platform | Modes supported | Reserved ports by mode | ||
| low | high | vim | ||
5320-24P-8XE 5320-24T-8XE |
low |
1/25-1/27 |
5320-48P-8XE 5320-48T-8XE |
low |
1/49-1/51 |
5420F-24T-4XE 5420F-8W-16P-4XE 5420F-24P-4XE 5420F-24S-4XE 5420M-24T-4YE 5420M-24W-4YE |
low |
Universal Ethernet ports 1/29 and 1/30 Note: To
understand restrictions on using reserved loopback ports as
front panel ports, see 5420 Series.
5420F-48T-4XE 5420F-16MW-32P-4XE 5420F-16W-32P-4XE 5420F-48P-4XE 5420F-48P-4XL 5420M-48T-4YE 5420M-48W-4YE 5420M-16MW-32P-4YE |
low |
Universal Ethernet ports 1/53 and 1/54 Note: To understand
restrictions on using reserved loopback ports as front panel
5520-24T 5520-24W 5520-24X |
low vim (default if vim is not installed, otherwise low) |
Universal Ethernet ports 1/25 and 1/26 |
VIM slot reserved |
5520-12MW-36W 5520-48SE 5520-48T 5520-48W |
Universal Ethernet ports 1/49 and 1/50 |
VIM slot reserved |
5720-24MW 5720-24MXW |
high vim (default if vim is not installed, otherwise high) |
none - all front panel ports available |
VIM slot reserved Note: This mode uses less internal bandwidth speed than high
mode.
5720-48MW 5720-48MXW |
VIM slot reserved |
7520-48XT-6C |
low (default) high |
with VXLAN Full Interworking Mode disabled or enabled: All front panel ports are available |
with VXLAN Full Interworking Mode disabled: 1/54 with VXLAN Full Interworking Mode enabled: 1/53 and 1/54 |
7520-48Y-8C 7520-48YE-8CE |
with VXLAN Full Interworking Mode disabled or enabled: 1/55 and 1/56 |
with VXLAN Full Interworking Mode disabled: 1/54, 1/55, and 1/56 with VXLAN Full Interworking Mode enabled: 1/53, 1/54, 1/55, and 1/56 |
| 7720-32C |
with VXLAN Full Interworking Mode disabled or enabled: 1/31 and 1/32 |
with VXLAN Full Interworking Mode disabled: 1/30, 1/31, and 1/32 with VXLAN Full Interworking Mode enabled: 1/29, 1/30, 1/31, and 1/32 |
To understand restrictions on using reserved loopback ports as front panel ports on the 5420 Series, see 5420 Series.
After the switch reserves the appropriate ports to become loopback ports, the ports are no longer visible in the output when you enter show interfaces gigabitEthernet.
By default, for the 5520 Series and 5720 Series switches, if you do not install a VIM in the switch, the switch uses the vim parameter. In this configuration, the VIM ports are used as loopback ports and the Universal Ethernet ports are used as regular uplink ports. When used as regular uplink ports, the port speed for the Universal Ethernet ports is 40 Gbps as a single channel port. Although the maximum supported single channel port speed is 40 Gbps, the ports can be channelized to operate as four 10 or 25 Gbps channels.
If a VIM is already installed in the 5520 Series, the switch uses the low parameter that uses Universal Ethernet ports as loopback ports and VIM ports as regular uplink ports. For the 5720 Series, the switch uses the high parameter that uses Universal Ethernet ports as loopback ports and VIM ports as regular uplink ports.
Important
You must ensure your configuration does not include reserved ports before you enable this feature. If the configuration includes reserved ports, after you enable this feature and restart the switch, the switch stops loading the configuration.
